Finally buying amp
Old Mar 15, 2008 | 06:49 AM
blazinloud's Avatar
Default RE: Finally buying amp
no, are they dual 4 ohm, or dual 2 ohm coils?
since they're 15's go with at least 800 each....
Old Mar 16, 2008 | 02:26 AM
dimmuborgir6nik6's Avatar
dimmuborgir6nik6 is an unknown quantity at this point
Got any amps for that in recommendation?
Old Mar 16, 2008 | 01:33 PM
blazinloud's Avatar
Old Mar 16, 2008 | 08:43 PM
That first Hifonics you posted looks pretty good. After my next paycheck I might buy that one!
Good selections though, thanks.
Old Mar 17, 2008 | 11:30 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
what is the final impedance do you need on the amp? you need to know that before even thinking about any amps. Second, it will be easier and more feasable to buy 2 seperate amps instead of one huge amp that will be very expensive. Third is where will you be installing the amp/s? you need to know how much room you have to work with. MOST IMPORTANTLY though is will your current electrical setup allow you to power all the amps you need?
Old Mar 18, 2008 | 10:27 AM
blazinloud's Avatar
$300 for nearly 2000rms is expensive?
Old Mar 18, 2008 | 11:37 AM
bobditts's Avatar
Which amp produces a legit and clean2K RMS for only $300?
Old Mar 19, 2008 | 01:10 AM
blazinloud's Avatar
Well the one I posted claims 2000@1ohm for $340
maybe they mean on 16 volts
Old Mar 19, 2008 | 06:14 AM
bobditts's Avatar
I wouldnt believe it until I saw the actual test results. If it sounds too good to be true in car audio, it usually is
Old Mar 19, 2008 | 11:02 AM
blazinloud's Avatar
thats true, but even if it was over-rated 400 watts it would still be a good deal.
afterall the 1606 isnt that overrated
I should mention that the amps i posted are if you bought dual 4 ohm subs.....you want to run those amps at 1ohm
