fire wall help
Old Jul 28, 2007 | 03:40 PM
kankoon52's Avatar
kankoon52 is an unknown quantity at this point
Default fire wall help
hey i plan to hook up my amp this weekend with my sub and i heard that you can get through the firewall where the stock antenna goes through. i found where it goes through but i can find it from the engine compartment. the antenna wire seems to run under my air conditioning unit thats up against the firewall. do i need to remove the black outer shell? it seems the wire runs down under it and i cant figure out how i could run a wire through there? thanks in advance for the help!
Old Jul 28, 2007 | 06:40 PM
WisdomRacing's Avatar
WisdomRacing is an unknown quantity at this point
Default RE: fire wall help
Couldn't comment on that particular spot, but on my Jimmy there is an AUX wire (probably 12 gauge) that goes through the firewall at the same place as the steering shaft. If you don't know what I'm talking about, look under the steering column and follow the shaft that connects to the steering wheel back to the firewall, that's the spot I'm talking about. Good luck and enjoy your system!
Old Jul 28, 2007 | 07:57 PM
hillbillyinOhio's Avatar
you will probably have to take and just run that wire through, and then you will see it in the engine compartment. comes through low, back pass side of engine.
Old Jul 30, 2007 | 09:30 AM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
exactly what hillbilly said, sometimes you just have to poke the wire through and then you will see it. its a good place to run the wire through
Old Jul 30, 2007 | 11:40 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
yeah... it comes out underneath the huge plastic box lookin thing and the AC condenser...lol you have to push it thru and then look in the engine compartment... I should be wiring my amp back in my blazer today.. I can take a pic if u want...
camo8193
Dec 1, 2011 01:15 PM
striper51
Nov 15, 2011 11:56 AM
tall_ish
Nov 20, 2010 09:05 PM
noom14921992
May 28, 2008 05:04 AM
02 Vortech
Jan 15, 2005 06:33 PM
