good place to put toggle
Old Feb 26, 2009 | 10:47 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default good place to put toggle
Where is a good place to put toggle switches neatly so they are at easy reach. I need to put two switches somewhere. Right now I have one switch in the gap between the steering wheel and the lower panel cover, but this one I want to move since its not very convient.
Old Feb 28, 2009 | 01:12 PM
Drifter666's Avatar
Drifter666 is an unknown quantity at this point
Default RE: good place to put toggle
i have mine right into the center console it looks professional but for best results use a nos toggle switch like this it has a cover to keep from accidentally hitting them
http://www.icon-auto.com/online_shop...os15606nos.jpg
Old Feb 28, 2009 | 02:28 PM
Blazin NC's Avatar
Blazin NC is an unknown quantity at this point
I made a panel to cover the CD holder in the center console.
Old Feb 28, 2009 | 03:39 PM
NVANZEE's Avatar
yeah i did the same thing as blazin NC. I cut a piece of plexi glass and painted it black. I have 4 switches, 2 at the top and 2 at the bottom
Old Feb 28, 2009 | 07:25 PM
portcqb's Avatar
Yah I dont have my cd holder there, mine on the ceiling since I have a floor shifter. I took my dash trim off yesterday and noticed that there is a fairly convientent space between the steering column and the headlight switch area.
Old Feb 28, 2009 | 07:45 PM
spedelbrock's Avatar
spedelbrock is an unknown quantity at this point
I have my fog light rocker switch right above the rear hatch button, it was not being use anyways and it looks factory.Another reason I put it their is because I can get power from the fuse box.The plastic cover pops off with a flat head screwdriver,then cut out an access hole with a dremel.I wish I could post a pic but I can't figure out how, but you get the idea right?
Old Feb 28, 2009 | 10:34 PM
portcqb's Avatar
Yah I thought about going in that area, but I use all the switches So I couldnt decide what to eliminate.
Old Mar 1, 2009 | 01:56 AM
cr8390's Avatar
cr8390 is an unknown quantity at this point
i made a custom switch panel out of a old mother board and put it where the tape deck was look:
(CLICK PIC TO MAKE THEM BIGGER)
this is a newer pic
this is a older close up pic i have. I have 2 more switches in there now
Old Mar 1, 2009 | 12:22 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
depending on how big the toggle is, you can mount it on the side of the dashwill have to do it toward the top almost even w/ the mirrior. so when door is closed it will be almost invisible. i dont have pic but i had my bass remote mounted there on my xtreme
Old Mar 1, 2009 | 06:31 PM
runnin blazer's Avatar
runnin blazer is an unknown quantity at this point
hey blazin nc how did you get that plate to stay in place i like that i idea and i just might have to steal it from you.
