got metered
Old Apr 3, 2007 | 01:21 PM
Loud_01_Blazer's Avatar
Loud_01_Blazer is an unknown quantity at this point
Default got metered
went to a show on the first and ended up doing a 146.8. Not to bad considering i had to use a prefab vented box lol. i figure when i build the right box and add a couple batteries i should gain a db or two, who knows maybe even more..
Old Apr 3, 2007 | 01:40 PM
hillbillyinOhio's Avatar
Default RE: got metered
not a bad score for the napalms. careful that you dont roach them. you will gain quite a lot gng from a sealed to a properly built ported enclosure.
Old Apr 3, 2007 | 01:55 PM
they seem to be pretty strong subs, i did a1 minute deathmatch with them at the show and they didn't even start to smell
Old Apr 3, 2007 | 02:17 PM
thats not too bad. Jag made em smell off of his Big soundstream amp.
Old Apr 3, 2007 | 03:07 PM
i was only givin them about 1500 watts each, and i've been told they'll take 2000 watts each daily so we'll se what happens when i get the 18v set up going...
Old Apr 3, 2007 | 03:41 PM
jagblazer01's Avatar
haha yea be careful. im feeding mine about 2500-3000 each and they started smoking hardcore bu they still work.....im looking into new subs so if anyones interested in these let me know
Old Apr 3, 2007 | 04:47 PM
thats a whole lot of cash to do an 18 v setup. I have the complete backing of my shop and i dont want to fork out the loot to run 18v.
Old Apr 3, 2007 | 06:32 PM
blazinloud's Avatar
Ive noticed most amps spec sheets say like 11-16v to run the amps....18v dosent pose any problems?
Old Apr 4, 2007 | 01:33 PM
this amp does it's fully power at 18 volts...actually it'll do it at 17 volts but it's modded by scottie j to run 18 volts and run all the way down to .35 ohms.
Also can anyone correct me if i'm wrong but the guy i bought the nalpalms off of said if i blow them FI will recone them..any one else hear this?
Old Apr 6, 2007 | 10:19 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
thats pretty good numbers. was it a meca comp? what class were you running in?
