Got a new HU... doesnt want to work.
I got a $90 Walmart special Sony HU. Its got a good ground (I tried the factory ground, wouldnt work, so I grounded it to the bolt in the little area in front of the cupholders in the front console area)
Itll take a CD and eject it... but it WILL NOT come on. Tried wiring it 2 different ways... no different results. Is the HU screwed up or am I incapable of this simple task?
I would try and figure out why the factory ground isn't working.
Also, I've taken the center console out plenty of times but I can't remember for sure but I'm not even sure that little bolt is grounded. I thought it was mainly to hold the plastic together.
first off i would check fuses since those r the cheapest and easiest things to fix... did ur factory deck or ur prior deck work before u tried to install the new headunit??? if so then u need to go back threw all ur wiringing and make sure it is connected good... and if u did buy a wire harness make sure ur red goes to red, ur yellow to yellow, and ur black to black..
Factory head unit was working like a charm when I pulled it not 5 minutes prior to the swap. Changed the fuses, no alteration. Verified my connections. The new ground arced when I tested it with the ground wire from the radio... the factory ground did not.
I didnt buy a harness, I'm going to wire it up myself.
Like I said, the factory radio worked fine... but it didnt like to play cds that werent like brand new. That's why I was changing it out... and the fact that the factory HU had NO bass output at all and sounded like dog rump.
ORIGINAL: otnietdehoooo
