Head unit wiring :P
I'm confused on how to wire this head unit. I just got an 83 blazer and someone has installed a head unit straight to the wiring with out any wiring adapter. That head unit is blown I guess and I wanna put my own one in...
In the dash theres these wires
2 fat red wires
1 medium sided red wire
1 medium sized blue wire (bigger than the blue ground wire that's in there as well)
and a set of small yellow and blue wires
None of these wires are labeled. The rest of the wires had other color coded wires spliced into them but those had labels on them like front right + and -
Anyone know a link to help me? I didn't find info on the 2 big red wires and such in the stickys posted...
Any help will do, thnx!
2 fat red wires
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink...never in a s10 or blazer...but other gm's
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
Dimmer--- gray
Constant 12V+
Orange
Switched 12V+
Yellow
Ground
Black
Illumination
Gray
Dimmer
Brown
Antenna Trigger
Pink
Antenna
Right Front
Front Speakers
4" x 6"Dash
Left Front (+)
Tan
Left Front (-)
Gray
Right Front (+)
Light Green
Right Front (-)
Dark Green
Rear Speakers
6" x 9"Side Panels
Left Rear (+)
Brown
Left Rear (-)
Yellow
Right Rear (+)
Dark Blue
Right Rear (-)
Light Blue
I would venture to guess that the red wires are something that he may have added to aftermarket. Try testing them with a test light or volt meter. If they send and power with the vehicle off or on, they will need to be adressed. Best thing to if the wire doesnt belong, is to trace it through the vehicle...
Yeah... It has alot of custom wires. The head unit that was in there actually works - I plugged it up to my Dodge Crap-us (Stratus..).
From what I found out - he has the power wire running straight to the battery. He also had some other red wires comming out that were merged then connected to the radio... Ofcourse I pulled that radio out so I can't follow his wiring method on another head unit.
I'm sure one of those other wires is a 12V+ switch or some sort.
But thanks Blazin_Jason and bobditts I hope it is only a 5$ tool :P
The blazer also has some sort of idle issue and shuts off if not revved a little for 30 seconds or so... So that'll be another bill to the shop.
