Headunit Install
Old Aug 17, 2006 | 01:55 PM
TheDesertFox's Avatar
TheDesertFox is an unknown quantity at this point
Default Headunit Install
Just gotta quick question, how do i remove the section of dash to allow me to gain access to the stock hu?
Thanks, Luke
Old Aug 17, 2006 | 02:01 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: Headunit Install
eeeaaasssssyyy
first wut year we talking about?
If its a newer model like mine.
First you need to unscrew 2 screws under the steering wheel. and drop that panel. then theres a scew up on the dash by the gauge area get that out.
its a 7mm socket btw then it just pops straight out.
You need a small flathead to get the little like plugs for the wires like the control things like the lights and the rear wiper or 4wd.
Then its off!!!
Ur set. Use the 7mm to remove the HU itself. Then proceed with wut needs to be done. Simple!
If you need me to i can run out and do a little step by step with pictures for u.
Old Aug 17, 2006 | 02:13 PM
lol i always forget to say my year, its a 98. And yes, I'd love to see some step-by-step pics, Thanks!
Old Aug 17, 2006 | 02:25 PM
XBlazer01's Avatar
Alright man uh give me like 30 mins or so and I'll post that up for you.
Sealing the deal on my amp atm but ill get on that ASAP
Old Aug 17, 2006 | 03:14 PM
XBlazer01's Avatar
Heres our tool for Dash Removal of a 2001 Chevy Blazer. 7mm Socket! (im to lazy to find the actual tool so ill just use the socket itself!
Heres where the first bolt is. Easy removal. Up in the gauge area
Remove the next 2 bolts via the 7mm tool again
Now you have the choice of just pulling the peice under the steering wheel down or completely taking it out. I just pulled it down. Its easier!
Now just pop the dash peice off! Just pull it. It'll pop right out. It's held in by clips!
Use a small flathead screwdriver to get the little control box things out. heres the rear wipers for mine!
Heres the clip holding the wires in!
More wire things on the other side! Just use the flathead again to pop those out! YOUR INSIDE LIGHTS WILL COME ON! But they will turn off in 20 mins. Its a saftey thing for the battery!
You can now put the dash aside and everything is exposed!
Once again we use the 7mm to remove the bolts holding the HU in place.
(THERE MAY BE MORE BOLTS ON THE STOCK HU JUST USE THE 7MM TO REMOVE THEM!)
Pull the HU out and set it somewhere if you just plan on working in this area like adding a sattelite radio peice or whatever!
Here we go! All the room to work now!
__________________________________________________ ________
Writeup By: XBlazer01
Old Aug 17, 2006 | 05:26 PM
hey man thanks a lot, this'll come in handy for my install next week.
Thanks!
-Luke
Old Aug 28, 2006 | 12:12 PM
fnirish's Avatar
fnirish is an unknown quantity at this point
Thanks for the pics and instructions, I'm trading out my factory cassette unit for the factory cd this week and really needed to know this stuff. Awesome!
Old Aug 28, 2006 | 12:21 PM
XBlazer01's Avatar
Glad I could have been some help around here!
Old Aug 28, 2006 | 12:27 PM
ORIGINAL: XBlazer01
It's about time... SHESSH!!!
Nice writeup! Coulda had a better camera though...
Old Aug 28, 2006 | 12:35 PM
XBlazer01's Avatar
-_- I'm sorry my cellphone isnt up to your standards lol
