????HELP
Does anyone know how to wire a switch that turns your subs on and offusing a toggle switch?????
I saw one on myfriends truck its real usefull when u want to turn off your subs and have just the music playing. THANKS! |
RE: ????HELP
just go to autozone or radio shack, but a 2 wire toggle swtitch. grab your remote wire under the dash, cut it in half, put one wire from switch to each side of the cut remote wire. mount wherever you want!
RE: ????HELP
thanks alot
RE: ????HELP
Do you have the factory hu or aftermarket? A lot of aftermarket radios have that function already built in.
RE: ????HELP
really? do you have a link? whats it called?
Ive never heard of this feature on decks before........but I wouldnt mind having it...... |
RE: ????HELP
yah usually if you connect your subs through a sub out connection, you change the volume of them from within the deck , obviously down to off or att in most cases
RE: ????HELP
yeah its aftermarket, it has that were you can turn off the subs with the radiobut i would rather have a switch, its eaiser and faster i think
RE: ????HELP
ORIGINAL: mik9545 yeah its aftermarket, it has that were you can turn off the subs with the radiobut i would rather have a switch, its eaiser and faster i think |
RE: ????HELP
exactlywhy i thought it would be usfull to put one in
RE: ????HELP
i was going to do that but i got the bass remote with my new amp and when you turn it down itwillclick and it kill the power for me so i didnt have to bother with it
