Help with building a box
I want to build a box for a couple of 12's. I would like it to be ported, but I don't know what kind of wood to start with and the demensions and how to carpet it at the end so it all looks clean. I know to gorilla glue it and then screw it with predrilled holes. How do I make the ports? Thanks
Ports the sensitive thing.
Get a program called Bass Box Pro 6
you can also use WinISD
or this: http://www.subwoofertools.com/forum/...&Vas=&Fs=&CE=0
^set that up for ur subs specs and all.
Use 3/4" MDF unless ur going with HARDCORE bass. then double up 2 layers of 3/4"
Ok that keeps crashing me so I cant.
Um Ports can be done a few ways it depends on what u want. I have a slot port which is basically the length of the box.
Some people use AeroPorts but they're a sensitive port. not good for a beginner.
You can do a like boxlike port on the top. You can have a port goin from the top to bottom on each side or the center. but the center one is for chambered subs I believe
Slot Port
Slot Port
