Help with building a box
Old Sep 20, 2006 | 12:51 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default Help with building a box
I want to build a box for a couple of 12's. I would like it to be ported, but I don't know what kind of wood to start with and the demensions and how to carpet it at the end so it all looks clean. I know to gorilla glue it and then screw it with predrilled holes. How do I make the ports? Thanks
Old Sep 20, 2006 | 01:03 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: Help with building a box
Ports the sensitive thing.
Get a program called Bass Box Pro 6
you can also use WinISD
or this: http://www.subwoofertools.com/forum/...&Vas=&Fs=&CE=0
^set that up for ur subs specs and all.
Use 3/4" MDF unless ur going with HARDCORE bass. then double up 2 layers of 3/4"
Old Sep 20, 2006 | 01:11 PM
Thanks. A Ported box is for if you the subs in backwards right? Go in chat if your still on.
Old Sep 20, 2006 | 01:27 PM
XBlazer01's Avatar
Ok that keeps crashing me so I cant.
Um Ports can be done a few ways it depends on what u want. I have a slot port which is basically the length of the box.
Some people use AeroPorts but they're a sensitive port. not good for a beginner.
You can do a like boxlike port on the top. You can have a port goin from the top to bottom on each side or the center. but the center one is for chambered subs I believe
Slot Port
Old Sep 20, 2006 | 02:41 PM
Thanks. But one more question, what are the advantages of using a ported box versus a closed box?
Old Sep 20, 2006 | 03:23 PM
jagblazer01's Avatar
ported box is ALOT louder. i have a sealed box and regret not doing ported...but once i do my new setup im def. going ported.
Old Sep 20, 2006 | 03:54 PM
XBlazer01's Avatar
Sealed will give you: Cleaner Bass Hits, Low notes, Sound Quality
Ported will Give: Higher Numbers on the Meter, more Air Movement, Alot Louder
Old Sep 20, 2006 | 04:03 PM
blazinloud's Avatar
ported subs reach xmax with less power=louder
Old Sep 20, 2006 | 04:04 PM
blazinloud's Avatar
not all subs require a sealed to obtain good sq
Old Sep 20, 2006 | 04:23 PM
4lowlife's Avatar
That about sums it up.
