Hidden subs...
Old Aug 6, 2009 | 07:43 PM
degaine_designs's Avatar
degaine_designs is on a distinguished road
Default Hidden subs...
Eventually I want to get a sub or two and an amp. I don't want a box stuck in the back because I don't want to have to remove it when I haul stuff in the truck.
Ebay has some slim subs that I'm thinking about but I'm not sure if even they will work for what I'm considering.
I want to put one or two subs under the rear bench seat. Would this work? It doesn't look like there's a whole lot of room under there, but its hard to tell. Another problem is that when you lower the back of the seat down the whole seat moves forward a bit and I think it may lower at the same time.
Does anyone know if this idea will work? Here are the subs I'm thinking about: http://www.bestbuy.com/site/olspage....=1204331847849
Old Aug 6, 2009 | 08:30 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
I thought about putting subs under the seat as well. Havent had the seat in for over a year so I never got to see exactly how much room is under there. Scrapped the idea and putting them in the dash instead. not a whole lot of options for stealthy installs in the blazers. I would say if you want to put the subs under the rear seat, do not fold it down.
Old Aug 6, 2009 | 10:56 PM
mhollis's Avatar
mhollis is on a distinguished road
As far as the seat going down. As long as you keep it behind the bars youll be fine. The seat goes down a lilttle in front of the bars but behind them its all fine. But as far as fitting is conserend it all depends on if you can get a box in that space. Itll have to be a custom built box if it does work.
Old Aug 7, 2009 | 01:22 AM
Cool. Its low on the to-do list but it was on my mind so I figured I'd ask. Thanks.
Old Aug 7, 2009 | 02:59 AM
wlorton's Avatar
Someone does make a sub compartment to sit on the opposite side of the rear as the jack.... looks... nice.... but its like 500 bucks.... its on crutchfields website...
Old Aug 7, 2009 | 03:01 AM
wlorton's Avatar
Old Aug 7, 2009 | 10:53 AM
$500 is a bit expensive, but if I'm going to be putting money into a system I may as well do it up right. I'll look for it on their site.
Yeah, not bad. Is that the same as the other one you mentioned? Only problem is that it says it will only fit 92-00 Blazers. I wonder if it will fit my '89. Is there much difference between '89 and '92?
EDIT: Checked Crutchfield. I didn't find what you were talking about, I don't think. Can you post a link?
Old Aug 7, 2009 | 11:12 AM
Unlimitedsp's Avatar
The 500.00 stealth box is made by JL audio, but it only fits 95+ 4 door blazers.
Old Aug 7, 2009 | 03:06 PM
mhollis's Avatar
Another option would be to put them in the kicker pannels. http://www.qlogicfactoryoutlet.com/i...3181_3957_4053 Q logic makes some for a little under $200.
Old Aug 7, 2009 | 03:40 PM
oktain's Avatar
I just picture a foot slipping off the parking brake lever and going through a speaker with that lol... nice idea though if you're careful.
An idea (don't know about the 1st gen) is to make an enclosure of some sort that'd fit in one of the two compartments behind the seats in the rear quarter panels... I don't know if the 1st gen had these compartments though, I know mine may be big enough for a 10" sub.
