Install help
Old Nov 1, 2009 | 09:44 PM
not4unco's Avatar
not4unco is on a distinguished road
Exclamation Install help
I have just installed a Kenwood KVT-617 DVD unit into a 2000 Blazer.All wires are connected that need to be connected other than the reverse sensor wire,Dimmer Control and steering control on the head unit.And the mute,electric antenna,power control wire and amp control wire on the receiving unit.My problem is that I have the error message "Disconnected cable found.Please confirm a connection line" when all connections have been made.All fuses are still good....Am I missing anything here??
Old Nov 1, 2009 | 11:16 PM
Jason Rebellion's Avatar
Jason Rebellion is on a distinguished road
those seem to be pretty important..I'd hook those up and go from there
Old Nov 1, 2009 | 11:33 PM
loomdog32's Avatar
loomdog32 is on a distinguished road
There is only 1 wire that will cause that msg
The cable that goes from the HU to the "brain" or DIN cable. The cable should look like a s-video cable. If that cable is hooked up correctly, then the cable is bad.
That unit requires a "brain" unit, that Kenwood DOES NOT sell separately.
Old Nov 2, 2009 | 12:05 AM
not4unco's Avatar
Jason....the mute wire is for a car cellphone to mute the stereo when it rings,and i dont have a power antenna or amp currently installed.
Thanks Loomdog32,
Will take it to a friend of mine at Cartoys tomorrow then and see if they have a new DIN cable or if he can get one from some where....
dunontme
Jan 21, 2010 07:36 PM
davtak
May 1, 2006 10:45 PM
87s10blazer
Jan 20, 2006 09:16 AM
alpinejimmy
Dec 14, 2005 08:18 PM
blazin4eva
Jan 27, 2005 02:02 PM
