keyless remote reprogram
Old Mar 6, 2007 | 06:12 PM
times's Avatar
times is an unknown quantity at this point
Default keyless remote reprogram
1999 blazer, which method do I use to reprogram a keyless remote, ground the keyless programming connector to ground or cycle the ignition switch while holding door switch and hold lock and unlock button on transmitter? Also the remote is from another vehicle, does this matter? thanks
Old Mar 8, 2007 | 02:18 PM
filstoy's Avatar
filstoy is an unknown quantity at this point
Default RE: keyless remote reprogram
I have the same year Blazer and here's how I did mine. These instructions are from http://www.programyourremote.com/
Yes it does matter what vehicle the transmitter is from because there is more than one system. If it's from the same year Blazer it will work but other than that I'm not sure how to tell the difference and you didn't say what vehicle the new transmitter is from. I know there are a few more that will work so hopefully someone else will know.
1. Close all vehicle doors. 2. Insert the key into the ignition. 3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold down until instructed to release. 4. Perform steps 5 through 8 in fairly rapid succession. 5. Turn the ignition switch to the ON position (as far as you can go without starting the engine). 6. Turn the ignition switch to the OFF position. 7. Turn the ignition switch to the ON position. 8. Turn the ignition switch to the OFF position. 9. Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically. 10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds. 11. Repeatstep 10NOWfor each additional transmitter (including any existing transmitters). 12. Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
corvair wally
Engine & Internal
Jan 11, 2014 12:13 AM
ComputerNerdBD
Oct 16, 2011 06:10 PM
bigred77
Headers, Intake, & Exhaust
Dec 22, 2009 05:27 PM
cragpretzel
Nov 28, 2006 11:52 PM
blazernate1002
Mar 14, 2006 05:00 PM
