Late model power wire question
Old Mar 3, 2006 | 08:05 PM
  #31
HCCAFan's Avatar
HCCAFan is an unknown quantity at this point
Default RE: Late model power wire question
Im done until I get new batteries and a bigger alternator so it is ok for the time being. It is kinda rediculous that just my comp sets are causing my lights to dim.
Old Mar 5, 2006 | 05:17 AM
  #32
FatRyan's Avatar
FatRyan is an unknown quantity at this point
ORIGINAL: HCCAFan
well how many watts are you giving them? i got an xtr500.4 and you should know that xtrs bench much higher than rated. mine was benched at 151/ch instead of the rated 125/ch. so my comps are getting about 600w. and thats def enough to dim lights on a stock electrical system.
Old Mar 5, 2006 | 02:51 PM
  #33
HCCAFan's Avatar
Damnit man, I was sitting there trying to figure out how in the hell you thought they were getting 600 watts each and then realized you meant total. I just think it's funny to have the lights dimming off all "highs" even though they are getting 500 watts each alone w/o the tweeter amps added watts.
Old Mar 5, 2006 | 05:32 PM
  #34
FatRyan's Avatar
ORIGINAL: HCCAFan
watts are watts to a car ya know
Old Mar 19, 2006 | 11:12 PM
  #35
TEDDER1's Avatar
TEDDER1 is an unknown quantity at this point
If you are putting in a HIGH power system then I suggest getting a dual terminal battery. the kind with side and top mount posts. i had a MMATS amp running a juggernaut 15 in mine and it ate my battery. It heated up the plastic around the post causing it to leak because of all the juice running through it. So i bought the 4 post, leaving the truck itself on the side mounts and the stereo on the top postive post.
1989blazed
Mar 19, 2008 08:57 PM
Sherwood
Oct 24, 2007 10:45 AM
Hoelgi
Oct 11, 2007 02:37 PM
Hanr3
Apr 6, 2007 03:14 PM
LT1KICKER
Oct 26, 2006 06:35 PM
