LED wiring
Old Sep 6, 2008 | 03:10 PM
NVANZEE's Avatar
Default LED wiring
i am trying to hook some LED's up to come on with the dome light. What should i splice into to get power. i tried the light under the dash on the drivers side and every way i try it i always get power to the led if the dome light is on or off
Old Sep 6, 2008 | 03:19 PM
Default RE: LED wiring
The dome light circuit is a switched ground. You will need to hook them in using both the power and the ground from the dome light circuit.
Old Sep 6, 2008 | 03:23 PM
NVANZEE's Avatar
ok thanks
Old Sep 6, 2008 | 08:06 PM
NVANZEE's Avatar
i have another question. i also want to hook an LED up to go on with the headlights. before i spliced into the light in the ash tray but it would blow fuses and you were not able to get power from the (obd?) port under the dash to scan codes since they are the same fuse i think. so what could i splice into that wont blow fuses
Old Sep 6, 2008 | 08:27 PM
You must have tapped into the wrong wire... Always check with a multimeter to make sure that the wire does what you need it to do. An LED should not increase the load on a circuit enough to blow a fuse.
blazerlt1999
Jan 7, 2015 11:09 PM
speedhead
Mar 16, 2012 06:54 PM
96jimmyslt4x4
Sep 21, 2011 09:14 AM
96jimmyslt4x4
May 29, 2011 03:55 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
