malfunction power locks
Old Apr 24, 2007 | 11:14 PM
twei's Avatar
twei is an unknown quantity at this point
Default malfunction power locks
I have power locks on my car but on the drivers door its messed up. It allows me to unlock the door by pressing the power locks button, but i cant lock it with that button. All the other doors work properly, is there an easy fix or what may be the problem?
Old Apr 25, 2007 | 01:27 AM
hillbillyinOhio's Avatar
Default RE: malfunction power locks
pull off the switch panel and make sure that all wires have good contact and are fully connected.
Old May 3, 2007 | 07:42 AM
twei's Avatar
i took off the door panel, and when i clicked the button for the power locks, it makes a sound like it tries but it still doesnt lock
Old Oct 14, 2007 | 11:46 PM
bosshogg's Avatar
bosshogg is an unknown quantity at this point
Mine is doing the same thing and I cant figure out why. Getting annoying having to manually lock the drivers door when it has keyless entry...
Old Oct 15, 2007 | 12:10 AM
rriddle3's Avatar
This is pretty general since I have never had a problem with my locks, butif you have taken a test lamp and checked the harness wiring to the door lock switchand get a bad reading on the lock circuit, then there is a short in that wire, but I suspect that the switch has gone bad.
Or try Kyle's suggestion in this thread.
Old Feb 8, 2008 | 12:40 AM
mccague36's Avatar
mccague36 is an unknown quantity at this point
mine is doing the same thing and its starting to get on my nerves! I have had the door panels off before and i couldnt see anything wrong with the locks or connections.
Old Feb 8, 2008 | 01:53 AM
thegr81's Avatar
This all sounds like bad switches, but try swartlkk's thread first if you get a bad reading on the switch I would just replace it!!!
MDTjettaguy
Dec 28, 2007 09:09 PM
truck608
Oct 14, 2007 11:56 PM
Craig Austin
Nov 14, 2006 01:20 PM
Craig Austin
Oct 22, 2006 06:48 PM
Elisha
Mar 14, 2006 08:50 PM
