Need some advice
Old Dec 5, 2006 | 04:54 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Default Need some advice
I am re doing all my sound system in my blazer. My main question is about subs. What should I be looking for in subs. Low frequency range? Low ohm ratings?
I have a free gift certificate to have the whole thing installed at circuit city so I want to get the right stuff for them so when they wire it up it wont create conflicts with each other (sub and amp). I am going to get 2 mtx subs and 1 kicker amp. Should the subs be 2ohms and then I get a mono amp and run it parallel and have it run at 4 ohms? I dont want to blow the subs or amp because the ohms are messed up.
Old Dec 5, 2006 | 05:24 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Default RE: Need some advice
Oooh, this is a good question for XBlazer! That guy is a genius with this stuff, though he may try to convince you to go with MD subs instead [8D]! Just kidding X! I'll be gettin' with ya about some MD's pretty soon!
Old Dec 5, 2006 | 05:37 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
lol Nah I dont try to convince ppl to run MD It depends on the factors (MDs are efficient so if u have small power then i suggest to run em) (also run great on high power as youve seen from mine lol. Lemme know bout the MDs though. I can get ya some great prices)
Now. determining the Ohm load for the subs souly depends on the amp you plan to run.
Gimmie a link to the one you plan on running and then we can determine how low of an ohm load you can wire to and still be stable.
Now heres the thing.... circuit city.... yea i doubt they will know about wiring to a certain ohm load lol.
Consider some other subs before the MTXs though cause the only good MTX series Ive seen is the 9500 series and CC doesnt carry those. Check out CVRs CVXs (if they have them) and some other woofers. explore your options ya know
Old Dec 5, 2006 | 05:44 PM
blazinloud's Avatar
you'll probably want to run the kicker at 2 ohms(unless its 1 ohm stable) you'll want dual 2 ohm subs to run the amp at 2 ohms. Running the amp at 2 ohms will deliver more power to the subs as opposed at 4 ohms. Unless its stable at 1 ohm or less.
If you gave us links, and model #'s we could help you out ALOT more. And yes mono is the way to go when powering subs. And If they didnt match up they wouldnt install it, or purpose a solution. It's kinda of difficult to "blow" an amp nowdays they have protect modes which shut it down if something is not right.....overheating is the main culprit in most audio related deaths.
Just wait for Jon, he'll hook ya up......
Old Dec 5, 2006 | 05:47 PM
hillbillyinOhio's Avatar
depending you the subs that you are getting, from what i remember, CC only sells mtx subs with single voice coils that are 4 ohms. Think they have the 4500 series and 5500 series in both 10's and 12's. That being said, you would wire them in parallel (all positives together adn all negatives together, yeilding a 2 ohm load. the other way is series giving you an eight ohm load. so you will be looking for an amp that has good power ratings at 2 ohms. ALl that is if you are buying your subs and amp at CC, not just having them install them.
Old Dec 5, 2006 | 08:02 PM
Well most likely I wont be buying the stuff from them, they are just installing it all for free. For subs shouldnt I be looking for DVC subs? Also what are these MD subs you are talking about?
Old Dec 5, 2006 | 08:07 PM
XBlazer01's Avatar
MD is what i run/deal.
check my vids
http://www.realmofexcursion.com/vide...winder12.7.wmv
http://www.realmofexcursion.com/vide...winder12.6.wmv
http://www.realmofexcursion.com/vide...winder12.5.wmv
thats the low end woofer in there line up too.
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
Mass Destruction. mr. tobin's bread and butter, so to speak. never heard them in person but i'll take someone's word for it that they're kick ***.
Old Dec 5, 2006 | 09:35 PM
Your system is awesome man. I plan on only going with two subs but I am kind of weary of these MD's, I have never heard of them nor heard anyone talk about them so I am a bit spectacle on the reviews of these. You say they are good, but what about other people?
Old Dec 5, 2006 | 11:01 PM
try posting on www.realmofexcursion.com
i think that some people have them in there.
