New to forum...what do u think
Old Dec 19, 2007 | 09:42 PM
  #21
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
Default RE: New to forum...what do u think
those things are nuts, maybe i should sell my system and buy some of those
Old Dec 19, 2007 | 09:54 PM
  #22
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Good call on the DC Sounds subs. Very solid drivers. Ive tested levels 2-4 and each has definitely impressed me. those Level 2's are about the meanest 300wrms sub I've got to play with...I actually just decided to pick them up as a new line...
Old Dec 19, 2007 | 10:02 PM
  #23
Jharper's Avatar
my current subs i have now are pretty loud, but i want louder, im pushing 134.7 DB, but i want more, i crave it haha, whats subs should i get?
Old Dec 19, 2007 | 10:05 PM
  #24
jagblazer01's Avatar
ORIGINAL: Jharper
i did a 142.7 the other day with my single 15 on 1k watts....what kinda budget you got?
Old Dec 19, 2007 | 10:07 PM
  #25
Jharper's Avatar
well all depends after i rebuild my motor, still working on that, but idk it depends, i have a power acoustik LT1920 amp right now that im powering 2 12's with, and its pretty loud, my price range is pretty low right now, say 250 at the most for each sub.
Old Dec 19, 2007 | 10:13 PM
  #26
cloak01ls's Avatar
ORIGINAL: Jharper
You're definately going to want to throw some more wattage into your bass system down the road. 800w is good, but your going to want to bump that up if you want to make a stretch for the low 140's...134.7 isnt too bad, honestly. If you wanted to upgrade your subs and keep that amp you should check out DC Sounds Level 2 subs. They are rated at 300wrms but can take 500 daily no problem. You could probably pushlow 140'swith two 15"s. That is if you want to take up the whole cargo area...
Old Dec 19, 2007 | 10:16 PM
  #27
Jharper's Avatar
haha i dont care at all, i dont haul stuff, id have to build a box tho, and i don want to lol. id rather have 12's but if 15's will be louder then why not.
Old Dec 19, 2007 | 10:25 PM
  #28
cloak01ls's Avatar
You ahve to build a box, or have one built for you. Thats the only way you are going to get those higher numbers. What type of box do you have right now?
My motto is if you can fit it, go as big as you can. The more cone area you have the less effort it takes to get loud. For the most part quality subwoofers use the same motor for each series of woofer and just change the cone and basket for diffirent sizes. If you can runn 400w to a 10", or 400w to an 18", which is going to be louder? Its all about what you can fit and how much room you want to take up. I personally have always found room to go big
My old comp car/daily driver...148.3 sealed at the dash.
Old Dec 20, 2007 | 07:19 AM
  #29
i looks like his box is sealed....maybe a simple reconstruction to a ported box will increase his numbers a little
Old Dec 20, 2007 | 10:44 AM
  #30
Jharper's Avatar
my box i have now is sealed but it was fit for my olds cutlass i have, but when i bought my blazer i put the system in that and didnt have the money to build a new box, so it would be louder if i made a huge box? and would i have to port the box for it to be louder?
