New Gear!
Old Jul 30, 2007 | 07:18 PM
blazinloud's Avatar
Default New Gear!
well finally, here they are.......
did a comparison with a ppi C1 12 (great sq)
and a MA 8
They'll be getting around 800 watts each.
Old Jul 30, 2007 | 08:27 PM
hillbillyinOhio's Avatar
Default RE: New Gear!
nice subs man. those things can pound. prefab box???
Old Jul 30, 2007 | 08:37 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Those look freakin awesome, about how much do those run, and what kind of gear do you need to power them right? Definately put up a pic when you are done installing them.
-Lenny
Old Jul 30, 2007 | 09:07 PM
blazinloud's Avatar
they're cheaper than hell! got the 2 for just over $300 they're rated at 500rms......but for them to really sing I'd suggest more....
hillbilly I will be getting a box built pretty quick......but I wanted something a little different.......like a snailshell.......but i doubt that will happen....shops prolly want crazy money for that.
what do you recommend? slotted at 32hz? subs up port back......?
think a 145 is in my sights?
Old Jul 30, 2007 | 09:11 PM
yea, straight crx or subs up port to pass side. if you can keep up the voltage for that amp, 143.
Old Jul 30, 2007 | 10:51 PM
blazinloud's Avatar
yea, it already drops pretty good, voltage wise......
I was reading on roe that a 2nd battery wont do much good considering I will still be dropping below 13 volts.......I will be switching to 1/0 wiring soon buuut, I dont think that will do much.
Like having a 2nd batt. wont stabalize my voltage, right?
143 is kinda weak [&:]
Old Jul 31, 2007 | 05:44 AM
drperry's Avatar
The second batt will help keep the voltage up (twice the current capacity, after all) but a beefier alt will definitely do the trick.
Old Jul 31, 2007 | 12:08 PM
blazinloud's Avatar
ya but there soooooo expensive
anyone know what like 160amp or 200amp ho alt goes for......like whats the cheapest one?
I know I could email excessiveamperage.........but thought maybe one of u guys could tell me a little quicker.
Old Jul 31, 2007 | 05:38 PM
jagblazer01's Avatar
sweet subs man.....good luck with everything. i have a kinetik 800 ill sell if your interested in doing a second batt.
Old Jul 31, 2007 | 06:04 PM
blazinloud's Avatar
I will run a 2nd battery if its worth it.......but the things I read on roe kinda led meaway........
um, so is that like 800ca, or 800cca? what does the 800 stand for?
I seen LOTS off ppl running those so they must be pretty decent.
what r u asking for it? it dosent matter if you run 2 totally different batteries? I think the one I have under the hood is a 2 year old acdelco, its like 7 or 750 cca i think.....might be less.......
how old is the kinetic? I will buy it, like I said, if i'll see any gain from it......
thanks jag.
