new and having problems with my system
Old Jan 26, 2008 | 07:30 PM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
Default new and having problems with my system
i have a bad case of system thump and whining noise when i turn my pioneer 4800 head unit on and may i add the whining noise get louder as the rpm goes higher the system thump happens when i turn my radio off and when i turn the radio station what should i do
Old Jan 26, 2008 | 07:56 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Default RE: new and having problems with my system
Sound like the symptoms of a bad ground. Try creating a new 'solid' grounding point for head unit...
Old Jan 26, 2008 | 08:06 PM
what about the system thump is that dealing with an bad ground as well with the head unit or is it something dealing with the ground for the amp ?
Old Jan 26, 2008 | 09:52 PM
cloak01ls's Avatar
I Assumed you had a factory system other than the HU, my bad. A turn on thump is usually as bad ground. This can either be the amp ground itself or the RCA's ground. I would first start off with the headunit ground because that is where ther RCA's get thier ground from anyway...
Old Jan 26, 2008 | 10:06 PM
hillbillyinOhio's Avatar
that is the common pioneer ground plane issue. Try to ground the shield of your rca's. I would almost guarantee that if you had another deck to swap in, your problems would go away. Design flaw with pioneer decks.
I am trying to find a link with pics on how to do this, but ROE is down for me.
here is the link
Old Jan 27, 2008 | 08:16 AM
thanks for the advise on the my system problems. wait ive tried that and still had the same problem after i think i'lltry to switch the radio ground to an more solid area any suggestions where should i move it to
Old Jan 27, 2008 | 08:20 AM
honestly, do you have the means to try out a different radio? i really believe that is your problem. Pioneer radios are known for this, at my three shops, in the past 4 years, have swapped out about 4 dozen pioneer radios due to the ground plane.
Old Jan 27, 2008 | 09:28 AM
no due to funds being low i cant swapp out my radio just yet but when i do is there an certin brand should i go with
Old Jan 27, 2008 | 11:45 AM
i wasnt saying to buy another radio, but do you have a friend with an aftermarket deck that you can pull out and put in your truck 4 testing???
Old Jan 27, 2008 | 04:37 PM
oh my bad yea thanks for the advice i will post my results
