Ohm/wattage question
Old Aug 5, 2008 | 11:01 AM
Good_Chevy's Avatar
Good_Chevy is an unknown quantity at this point
Default Ohm/wattage question
I have an old PPI amp, and I just bought a 15" Rockford P1 sub that has an 8 ohm SVC. My amp puts out 360 watts at 4 ohms, so does that mean my subs only getting 180 watts? It sounds just as loud if not louder then the 2 10" kickers that I just sold which were wired for 2 ohm and they were getting 180 watts each. I was also thinking about taking the sub back and getting 2 used 12" JL w3's for 150, which would be louder? Thanks in advance for you help.
Old Aug 5, 2008 | 02:00 PM
jagblazer01's Avatar
Default RE: Ohm/wattage question
what amp are you using?
Old Aug 5, 2008 | 03:37 PM
Good_Chevy's Avatar
I'm using this one: http://ampguts.realmofexcursion.com/PPI_PPI_2360/
All the info on there is correct except it has 2 25 amp fuses, not 30 amps.
Old Aug 5, 2008 | 11:11 PM
Good_Chevy's Avatar
Never mind, I took the sub back and picked up a 12" Elemental Design E12O.44, A million times better, but now I need a bigger amp. 360 watts barely moves this thing.
c3478493
Feb 3, 2014 02:56 PM
xgiovannix12
Oct 22, 2011 11:33 AM
WolfPack
Jan 7, 2010 11:52 AM
felonyblazer96
Dec 26, 2007 05:29 AM
vinthepirate
Oct 2, 2006 12:42 PM
