popping subs
when i shut off my deck and open the door(to cut the power) my subs usually have a slight pop to em, were professionally installed by a local shop, just wondering if this is due to a bad ground???
RE: popping subs
yah sounds like a bad ground.
RE: popping subs
some amps do it some dont, it occurs when the HU turns on the same time as the amp
there is something you can buy that you hook up you remote wire to and it will delay the signal my viper 1200 didnt do it, but then my a3000s will do it everynow and then |
RE: popping subs
check ur grounds cuz that is what it sound like.
RE: popping subs
bama i think my amp has a turn on delay, would this eliminate this problem?
