popping subs
Old Apr 30, 2006 | 04:19 PM
blazinloud's Avatar
Default popping subs
when i shut off my deck and open the door(to cut the power) my subs usually have a slight pop to em, were professionally installed by a local shop, just wondering if this is due to a bad ground???
Old Apr 30, 2006 | 04:35 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: popping subs
yah sounds like a bad ground.
Old May 1, 2006 | 12:58 AM
bamaboy's Avatar
bamaboy is an unknown quantity at this point
some amps do it some dont, it occurs when the HU turns on the same time as the amp
there is something you can buy that you hook up you remote wire to and it will delay the signal
my viper 1200 didnt do it, but then my a3000s will do it everynow and then
Old May 1, 2006 | 01:14 AM
jagblazer01's Avatar
check ur grounds cuz that is what it sound like.
Old May 1, 2006 | 03:32 PM
blazinloud's Avatar
bama i think my amp has a turn on delay, would this eliminate this problem?
DevinIsPro
Apr 1, 2010 11:51 PM
psyco1887
Suspension Tech
Jun 16, 2006 10:15 PM
RedBlaze
Suspension Tech
19
Nov 14, 2005 12:36 AM
Mike
Aug 23, 2005 11:49 AM
scoot
Jul 12, 2005 10:57 PM
