power cable shenanigans
2 Attachment(s)
So im in the middle of pulling all of the old wiring out for a fresh install. amp, subs, new wiring.
My first speed bump is the shop that installed the original stuff did one hell of a job hiding the power cable, there isnt anything visable that i can see where they connected it to the battery and where its going into the dash for my life of me i cant find where it exits into the motor compartment.,.. anyone have any ideas on where i would most likely find the power wire under the hood judging from the picture? second question would be whats the best method for hooking up the power cable. when i was younger i remember vaguely just going straight to the + terminal with some kind of connector https://blazerforum.com/forum/attach...ine=1412741667 |
What you remember is still the best way to connect the positive lead for the amp. Just don't forget to fuse the wire as close to the battery as everything under the hood will allow you to mount it.
To me it looks as though the wire is heading straight for the main harness boot. The main wiring harness has a huge rubber boot that keeps the water/weather out of the cabin. It has a fair amount of room around it and a lot of people like to cut a little slit in the boot and pass the wire(s) through that and then put a dab of silicone around it (hopefully). If they did indeed pass through on that side they might have connected the wire to the main post on the under hood fuse block instead of directly to the battery. Otherwise they would had to have ran the wire from that boot all the way around the engine compartment to the battery. It's just a guess, but that's where I'm leaning toward what they did. If you take that bottom trim panel off that's hanging there in the picture you should be able to see up under the dash pretty easily at wherever that wire is going. BTW, if that is how they installed that wire then beware there's probably other corners on the old install that have been cut. It's scary to think that people PAY shops for that kind of crappy work. |
Originally Posted by altoncustomtech
(Post 635903)
It's hard to tell. One thing is for sure don't EVER take anything to that place!!! lol
(Post 635956)
any idea on how to unhook this e brake handle so i can get the bottom dash piece completely out?
I thought the e-brake mechanism just was screwed to the back of that panel.
It has been like 3 years since I've seen the inside of a blazer though. :( |
The cable comes off the pedal assembly. If I recall correctly, it'll just pop off. I pondered that myself a while back until I decided to look at the other end of the cable instead of the end with the release handle on it lol
The old power cable was hooked up to the fuse box under the hood. got all of the new gear installed and it sounds great so far.
thanks for the replies folks. |
| All times are GMT -5. The time now is 05:33 AM. |
