Power Wire
Old Jan 2, 2008 | 03:56 PM
cyphon21's Avatar
cyphon21 is an unknown quantity at this point
Default Power Wire
Ok I did a search with no luck...I have a 1996 Blazer and Im trying to run my power wire into the vehcle to the trunk area to power my amp!....How did you guys get your power wire in??? I can't seem to find a good location at all!! Im also running 0g but either way I should be able to find a way in. Let me know how you guys did it, and if you can get or find pics that would be awsome!!!
Thanks
Old Jan 2, 2008 | 04:44 PM
blazinloud's Avatar
Default RE: Power Wire
serious, what did you put in for your search? theres probably at least 10 threads with good info
Old Jan 2, 2008 | 05:43 PM
cyphon21's Avatar
Really, I do apologize I didnt know how to word what I wanted haha
could somone link me then?
Old Jan 2, 2008 | 06:38 PM
jagblazer01's Avatar
I ran 1/0 in my truck....all i did was run it underneath the truck along the frame rail and drilled up in the back
Old Jan 2, 2008 | 06:46 PM
chevcamls1's Avatar
chevcamls1 is an unknown quantity at this point
i ran my wire thru the fender till the front passenger door then cut a hole in the rubber where the wiresruns from the vehicle to the inside of the doorand then i ran the wire under the carpet away from the rest of the wires so u dont get engine noise make sure to make the hole smaller then the wire so its tight and u dont get water insede of it i recomend doin it on the bottom
Old Jan 2, 2008 | 07:01 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
ORIGINAL: jagblazer01
i know a few people that has done it like that, i just not sure if i like it being exposed under the truck, it probably wouls be fine though, my wire is ran through aa whole in the firewall in my passenger floorboard, its under the A/C stuff under the hood, then just ran it under the carpet to the back
Old Jan 2, 2008 | 07:11 PM
hillbillyinOhio's Avatar
on passenger floor, at top edge of carpet, there is a large grommet that your antenna wire runs through.
Old Jan 2, 2008 | 07:16 PM
cyphon21's Avatar
ORIGINAL: hillbillyinOhio
I saw that, but didnt look big enough or room...hmm
I like the idea of running underneath, i live in canada and i dont know if 1/0g wire would be good in the snowy elements? I mean its heavy duty wire.
Old Jan 2, 2008 | 07:39 PM
just so you know, I had three runs of 1/0 through that grommet.
Old Jan 2, 2008 | 07:41 PM
its definately big enough
