prevolts?
is the prevolt on a deck really that important? im lookin at the new alpine cda-9856 and its only at 2v outs, any input on this deck? what exactly are the advantages or disadvantages to a higher preout? should i look for somthin in the 3v-5v range?
thanks
Adam
thanks
Adam
ORIGINAL: blazinloud
thanks
Adam
thanks
Adam
The problem with automotive soound is that there is a failure of its clients, customers, to completely understand how output and input impedance matching works. long ago understood by real sound guys and also by real automotive audio installers, there are so many more folks doing their own automotive sound and video no that those that do understand are in a huge MINORITY.
Not calling names here, just a factual comment.
The output from one unit only needs to be efficient enough to work properly with the input of the next product in line. Odds are that the output has a CONTROL on it and just as good are the odd that the INPUT has a control also. Were it not for lack of customer knowledge and understanding and the fact that a UNIFIED and single standard is not in use, we wouldnt even need them. ( VERY THEORETICAL OF COURSE)
Instead we have controls on both ends and we simply adjust them to "sound good". The higher the output the unit may be capable of, the more restrictive a following unit it may be able to push/drive to maximum capacity. If the following unit (INPUT) is overly sensitive, however, then we will distort the input stage of that unit very easily, making for some major problems.
In other words, there is only a "percieved" advantage. Louder is easier, because distortion is easier to accomplish???? There may be one more reason, driving a larger than normal number of amps, for instance, thus having to "split" available output. This is about the only "good" reason for looking for a higher number.
What has happened is that some manufacturers have found it great to advertise their numbers. Guess some folks just buy higher numbers no matter what.
What the customers need to do is think about a "system" and "matching" properly. Often the simplest way to do this is to stay with just one manufacturer and get their advice once you already have one of their units and wish to expand. Write them an e-mail or call them and get their opinion. Distortion should not happen in the listening system. Its better to place it in the recording to begin with. Do it on purpose, not by accident.
a good hypothesis, but it has no real basis. It is proven that higher V/lower impedance signals will deliver better quality sound. If it were just a sales gimmick that the n00bs fall for, then why do many professionals who compete use signal boosters to achieve higher V input signals? The higher the input V, the less you have to increase the sensitivity, resulting in less chance of audible distortion. However, you are correct in the fact that most car audio consumers do not have the slightest clue how to set gains. If you properly set your gains so that you do not clip the signal, there will be no excessive heat to damage the drivers.
Here's the best advantage and maybe the only one.
The higher the voltage fed into the amp, the less it has to work to 'amplify', meaning less heat and greater efficiency. So yes a higher voltage pre-amp is better for quality AND SPL systems.
higher voltage better for any type of setup.. i went from a 4 volt alpine to a 8 volt eclipse... big diff... amps' gains lower= gets cleaner signal= very lo chance of distortion...
* i wont go back to less than 8 volt, except if i go w/ navigation.. max is 5 volts...still good enuff
yaaaa, im no where near the knowledge of u guys, thats why i thought i would ask. I dont belive im a "noob" in terms of car audio, however I am confident with my somewhat halfway there knowledge.
Anywho, i will eventually be running 1 mono and 1 4 channel amp equalling a little under 1000rms, nothing too insane. I've been looking at the new 06 Alpine cda-9856, not top of the line but i wanna keep the whole system alpine. for retail $300 it only has 2v preouts, so my understanding is that each amp would get 1v, correct? which is allowing the possiblity of more distortion. should I look into a 4v deck? eventually i would'nt mind competeing in spl drags. (and watch my alpine's get eatin alive)
. but anyways, i dont know anything about the 9856. ive been out of car audio since i left for school, so i havent really seen any new stuff. But if its anything like the 9855, dont get it. Alpines quality has really declined in the last couple years. I do understand wanting a complete system by the same company. If your actually going for SQ or SPL, then chances are thats a bad idea, but for some reason i think im OCD about things like that, lol. your preouts are 2v. that means each single preout (Front left, Fornt right, Rear left, Rear right, Sub left, Sub right) will have a 2v signal at, or close to, max volume with a 0dB tone. It doesnt really put out 2v at all times. same goes for all preouts, be them 8v, 5v, 4v, etc. but theoretically, you sub amp should see 2 2v signals, and your component amp should see 4 2v signals.and i dont know about the others here, but i never heard anything about higher V signals boosting efficiency. You got any info i could read on that? not saying your wrong, its just news to my ears...
FatRyan
It was a fantastic hypothesis 50 years ago, and the theory hasnt changed. What the listener is willing to accept as "sound", certainly has. Clarity, legibility and something resembling actual music reproduction of the original is so far from the void of todays automotive sound that there is no comparison.
Take a trail run; all of you. Go out and adjust your sound system as well as it can possibly play. The go buy a disc of the most classical opera and orchestra music you can find. Stick it on in there and see what you get. The result is that you have created sound the way YOU wish to hear it. Not the way any sort of standard ever intended it to be.
The real trick is to design a system that will accurately reproduce what the artist intended, wether it be the Boston pops or M&M. You should be able to plug in EITHER into your system and hear what you are SUPPOSED to hear. Hear what the ARTISTS studio recorded, not what you think it OUGHT to sound like. If you dont like the sound the studio built for the artist, buy a different artists work. Maybe the other studio will change their style??
I realize this is not what it is you folks are even discussing, but then again, thats exactly what is wrong with auto sound. Home theatre is another prime example.
Just an opinion, not meant to agrevate anyone.
I thought I would edit this to add something. Higher voltages are real handy when dealing with stages (live concerts) from 200 to further away (overcoming high resistances) or cable runs with tiny skinny unbalanced rca cords running way too far to an amp in the back of a car. I feel it better to use quality cabling and such to improve things, at least in an automotive situation this is not that hard to do. ( Higher voltages will melt the tiny wires anyway) Those stages, well....they use the best to begin with, right?
ORIGINAL: blazingsadle
FatRyan
FatRyan
