Problem with overhead compas
Old Jan 19, 2009 | 08:51 AM
jeepster82's Avatar
jeepster82 is an unknown quantity at this point
Default Problem with overhead compas
I have a 01 blazer, its got a overhead console, It says what direction your going but no temp. All it says is oc, how do I reset this?
Old Jan 19, 2009 | 09:04 AM
Default RE: Problem with overhead compas
There is likely a problem with the ambient outside temperature sensor which should be located on the hood latch support in the center of the radiator, accessible with the grill removed.
*EDIT* - Adding diagram:
Old Jan 19, 2009 | 09:52 AM
jeepster82's Avatar
Thank you, I will check that
Old Jan 19, 2009 | 09:57 AM
jeepster82's Avatar
I looked at it, how do I test it? On the display it says oc then CAL and the direction. What does CAL mean?
Old Jan 19, 2009 | 10:03 AM
CAL means that the compass needs to be recalibrated.
digital compass and thermometer - runs through the compass recalibration procedure.
As far as testing the ambient temperature sensor... I do not have any values for you. It should decrease in resistance as the temperature increases though.
Old Jan 19, 2009 | 10:12 AM
jeepster82's Avatar
thank you
Old Jan 19, 2009 | 10:22 AM
jeepster82's Avatar
I calibrated it but it still says oc where the temp goes, Thanks for your help
Old Jan 19, 2009 | 10:31 AM
The calibration is only for the compass. The OC means that the there is a problem with the signal from the outside temperature sensor, as previously eluded to.
Old Jan 19, 2009 | 10:41 AM
jeepster82's Avatar
Do you think it could just be the sensor?
Old Jan 19, 2009 | 10:53 AM
Very possible. If you have a junkyard close by, snag a replacement and give it a whirl.
