Protection happy
Old Aug 4, 2007 | 01:19 PM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
Default RE: Protection happy
pretty sure or positive. just another thought. tryin to help out. it could say it can but will it really. and are they really at 2 ohms(the subwoofers) how are they wired
Old Aug 4, 2007 | 01:23 PM
Blazin_Jason's Avatar
Sundown was warranty covering theses amps @ 0.5. Rated at 1500@1.
Old Aug 4, 2007 | 01:39 PM
hillbillyinOhio's Avatar
that amp is rated at 4, 2, 1. they were warrantied to .5 with proper voltage. have been ran at .35.
Old Aug 4, 2007 | 01:55 PM
blazinloud's Avatar
[sm=icon_ladiesman.gif]
I'm gonna pick up an 80amp fuse asap
also "mr.sundown." said to put duct tape over the transformers........wont it melt?
going from 60-80 amp fuse makes that much of a difference?
I will also try turning on the amp without the subs connected......
Old Aug 4, 2007 | 03:04 PM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
Have you checked your remote wire? There could be a voltage problem there.
Old Aug 4, 2007 | 03:47 PM
eshballa5's Avatar
i have 100 amp glass fuses at my store.
Old Aug 4, 2007 | 05:59 PM
blazinloud's Avatar
Well I tried the above mentiond, with no luck, I got 5 "gold plated" 80 amp fuses.
disconnected the subs, put the fuse in and as soon as I turned on the deck, it blew. did that twice......-2 fuses.
next I took the bottom cover off, tried that......to rule out the transformer issue.......still blew....
So anywho I hooked up the alpine and voila, great sounding bass.
which leads me to belive its the amps fault, not mine.
Old Aug 4, 2007 | 06:48 PM
what kind of voltage drops did you have??
Old Aug 4, 2007 | 06:54 PM
blazinloud's Avatar
while driving.......it would get just under the 14 volt line...........at idle it would go half way in between last and 2nd last lines.....................but that was really driving it........it says the amp is like 83% effiecient.......has to be higher than my alpine.
Old Aug 12, 2007 | 11:50 PM
Hey did sundownz get your amp yet?
