Quad Beam Mod
What do you guys think? is this an apropriate way to perform the "Quad Beam Mod"?
https://img21.imageshack.us/img21/9518/quadmod.jpg |
I would not do it with a sealed beam dual pattern bulb. That is a sure fire way to overheat the bulb.
Yea, it will work. I imagine it could also be done by running power from the high beam circuit to the low beam relay, then using large diodes so as not to backfeed to the highbeams when the low beams are on.
But Kyle has a good point... I think you may start melting stuff and replacing bulbs sooner than expected by running all four lights for extended periods of time. Has anyone else done this? |
Originally Posted by swartlkk
(Post 216278)
I got a new composite front end that I will be doing the mod on when I install. So it wont be quad sealed beams, lol! But I do apreciate the warning. |
OK, just going off your sig pic. Looks like the sealed beams in there.
Aside from that, the schematic looks good. |
(Post 216295)
stupid question what do you mean composite front end
He is talking about the headlight design. His current headlight is a sealed beam (glass housing) that has both high and low beam filaments in the same glass housing. The composite headlight housing is a plastic housing which has separate capsule bulbs for high and low beams.
Originally Posted by chevyracen
(Post 216480)
so im powering the new bulbs straight off the batt through relays controlled by the old wiring! |
