Quad Beam Mod
Old May 11, 2009 | 10:05 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Default Quad Beam Mod
What do you guys think? is this an apropriate way to perform the "Quad Beam Mod"?
Old May 11, 2009 | 10:58 PM
I would not do it with a sealed beam dual pattern bulb. That is a sure fire way to overheat the bulb.
Old May 11, 2009 | 11:17 PM
bandidolenny's Avatar
Yea, it will work. I imagine it could also be done by running power from the high beam circuit to the low beam relay, then using large diodes so as not to backfeed to the highbeams when the low beams are on.
But Kyle has a good point... I think you may start melting stuff and replacing bulbs sooner than expected by running all four lights for extended periods of time.
Has anyone else done this?
Old May 11, 2009 | 11:38 PM
HaHa! Sorry for the confusion but...
I got a new composite front end that I will be doing the mod on when I install.
So it wont be quad sealed beams, lol! But I do apreciate the warning.
Old May 11, 2009 | 11:45 PM
OK, just going off your sig pic. Looks like the sealed beams in there.
Aside from that, the schematic looks good.
Old May 12, 2009 | 06:03 PM
Yah my truck still has the sealed beams, I figured Id do the mod to the new lights before I put em on.
Old May 12, 2009 | 09:10 PM
chevyracen's Avatar
chevyracen is on a distinguished road
stupid question what do you mean composite front end
Old May 12, 2009 | 09:31 PM
He is talking about the headlight design. His current headlight is a sealed beam (glass housing) that has both high and low beam filaments in the same glass housing. The composite headlight housing is a plastic housing which has separate capsule bulbs for high and low beams.
Old May 13, 2009 | 12:43 AM
yah what kyle said... All it is is a new grill and the headlight housings and mounts. but the new setup needs 4 wire per side ie 2 grounds and the sealed beams only have 3 wires ie 1 ground ( also note that the blue wire is the drl ground so it must be cut and not used for the above diagram).
so im powering the new bulbs straight off the batt through relays controlled by the old wiring!
cr8390
107
Jul 17, 2018 10:58 PM
blazedandconfused95
Oct 22, 2009 12:26 PM
mikeinwi
Feb 25, 2009 06:16 PM
cr8390
Feb 23, 2009 07:59 PM
NVANZEE
Dec 22, 2008 06:18 AM
