question about the fuse for my amp
Old Apr 4, 2008 | 10:31 PM
tjbmxrider's Avatar
tjbmxrider is an unknown quantity at this point
Default question about the fuse for my amp
i have a kicker 1000 watt amp. It has a 100a fuse rating. I am buying and amp instalation kit. I need to know what size fuse i should get. Also, would it be better to get a bigger fuse?
Old Apr 4, 2008 | 11:49 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: question about the fuse for my amp
the fuse for your wire is not to protect the amp, it is for the wire itself. The fuse for the wire is based off the power draw and the wire length. This sticky should help some. https://blazerforum.com/m_40326/tm.htm
Old Apr 5, 2008 | 10:08 PM
tjbmxrider's Avatar
ok thanks
Old Apr 5, 2008 | 10:09 PM
tjbmxrider's Avatar
wait. so what fuse do i need for my wire?
Old Apr 6, 2008 | 12:07 AM
bobditts's Avatar
what size wire are you using? What is the length of the wire? and how much amperage will be drawn over that run?
Old Apr 6, 2008 | 05:04 PM
tjbmxrider's Avatar
the wire is 1/0 gauge. About 15 feet of the wire. i do not know the amps but i know that it is 1000 watts
Old Apr 6, 2008 | 05:57 PM
bobditts's Avatar
http://www.bcae1.com/fuses.htm
scroll down through that link and take a look at the chart. Might want to rear the write up as well. Great info.
Old Apr 6, 2008 | 07:36 PM
wmartinlsmith's Avatar
wmartinlsmith is an unknown quantity at this point
I'd say go about125 amps.. you want to protect the amp.. thesecondary fuse (the oneon the amp)can do that.. the main fuse is to protect the circutry... thats how i see it.. and 125 will protect against shorts along the length while providing ample draw ability for the amp.
Old Apr 7, 2008 | 05:26 PM
tjbmxrider's Avatar
is a bigger fuse better?
Old Apr 7, 2008 | 06:58 PM
You want it to be bigger, but not soo big it will not break inthe event of a short... That's howI have always used as a rule of thumb... If you are never going to drawenough power to destroy one you never be able to destroy them both,
125 amps iss good starter number..to cover your ****.. if you feel thats too big go smaller.. but never go smaller than what your amp "could" draw at max load.
I think in my volvo i have a 110 amp fuse on my main wire and a 80-100 amp fuse on my amp..I should go re-look.
