Quick amp questions...
Old Jan 4, 2008 | 11:27 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
Default Quick amp questions...
Quick questions:
1. When running a monoblock to two (2) subs wired in parrallel, do the subs each get the full power of the amp, or is it split between the two?
2. Does running a 1 ohm resitance lower the sound quality, and/or reduce the life of the subs and amp?
Thanks all!
Daniel
Old Jan 4, 2008 | 11:32 PM
jagblazer01's Avatar
Default RE: Quick amp questions...
ORIGINAL: dbleon
Quick questions:
Thanks all!
Daniel
answers to questions:
1. the power is split between the 2 subs
2. running at 1 ohm does not lower the sound quality. Just provides more power from the amp. No it will not reduce the life of the sub or the amp as long the amp is 1ohm stable
Old Jan 4, 2008 | 11:33 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
if the amp is rated at 1 ohm stable it should not hurt the amp
Old Jan 4, 2008 | 11:54 PM
dbleon's Avatar
So If Im running 2 subs w/ arecommended 400w rms each, I need an amp that will do 800w rms minimum? Is more better? Thanks guys!
Daniel
Old Jan 5, 2008 | 12:01 AM
you would probably wanna run between 750 and 800 to them just to be safe
Old Jan 5, 2008 | 12:21 AM
dbleon's Avatar
ORIGINAL: jagblazer01
750-800 rms each??? Or a 750-800 rms amp?
Old Jan 5, 2008 | 12:22 AM
mdehoogh's Avatar
750w -800 rms amp would equal 400 to each sub.... which subs are they?
Old Jan 5, 2008 | 12:23 AM
hillbillyinOhio's Avatar
ORIGINAL: dbleon
Thanks all!
Daniel
Untrue Jimmy. Lower ohm load means more distortion. Which is why manufacturers give you the THD at a 4 ohm load and not the 1 ohm load.
Old Jan 5, 2008 | 12:48 AM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
ORIGINAL: hillbillyinOhio
Beat me to it....
Old Jan 5, 2008 | 12:51 AM
blazinloud's Avatar
thats what i thought too.......sq guys love those higher ohm loads......
