radio help!
Old Dec 8, 2008 | 03:48 PM
highrider44's Avatar
highrider44 is an unknown quantity at this point
Default radio help!
Ok Ive got and 87. I just got the truck and it came with no radio. So i went out and got the wiring harness got it all wired up, hooked up the radio and the damn thing doesnt work. Went and took my radio out of my other car and hooked that one up, still nothing. Ok so any info on the wiring and how i go about trouble shooting this woulod be greatly appreciated
Old Dec 8, 2008 | 10:33 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default RE: radio help!
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4″ x 6″
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6″ x 9″
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
From a quick search on google
Old Dec 8, 2008 | 10:38 PM
PABlazer's Avatar
PABlazer is an unknown quantity at this point
nice post cr... i needed that a couple days ago... hahahha....first off check and make sure ur fuses arn't blown, then if u have a volt meter check ur constant power (yellow wire)and c if u have 12v, then ur acc (red wire)and c if u have 12v when the car is on... both of these us ur ground wire for ur ground or u can use ur key hole for the ground...
Old Dec 9, 2008 | 06:03 PM
thanks yeah first thing i checked was the fuses but of course it wouldnt be that easy. im gonna go ahead and check on the volts tomorrow thanks
Boiler20
Oct 19, 2013 03:53 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
black19
Jun 22, 2006 03:35 PM
