RE: Radio Install and Amp
Just put a new bolt under the carpet. Have a ring terminal and a bolt the same size as the ring terminal hole. Drill a hole, sand off the paint in the immediate area, and install the new bolt. You can cut a slit for the wire to run through, or run the wire around the carpet if possible.
