-   Audio/Video Electronics (https://blazerforum.com/forum/audio-video-electronics-8/)
-   -   Radio Replacement Questions (https://blazerforum.com/forum/audio-video-electronics-8/radio-replacement-questions-31562/)
clhoover6 Jun 13, 2009 03:56 PM
alright i have a 2000 chevy s10 blazer zr2 and im looking to replace the stock radio with a gps-radio thats a touch screen. i was wondering if there were any specific things i have to do to remove the stock radio because im pretty sure the security system runs through the radio and i dont want to disable the vehicle. how would i go about removing the radio and replacing it? also when i was looking at radios i noticed they all said either 1 din or 2 din. which option would fit in my blazer.
thank you
mahoney1988 Jun 13, 2009 08:23 PM
I don't think it would disable your blazer.. i put a aftermarket cd player in my girl friends 01 and it didnt mess anything up.. a 1 din would fit with a dash kit.. and i don't think they make a dash kit to fit a double din in it. I did make custom brackets for a double din with the the same dash as a 97 blazer 4x4 to fit a double di. but if you want a easy instal i would go with a 1 din flip out navigation like pioneer d3..just my opinion though
clhoover6 Jun 14, 2009 10:33 AM
alright that sounds good thanks for the advice....where can i find a dash kit that would make everything fit nicely?
XBlazer01 Jun 14, 2009 02:31 PM
You can run a Double din radio but it would require a new dash bezel from like a Bravada. through the ending years of the truck they had a double din. You will also have to fab up a dash kit for the double din to fit. I've heard rumor there is a Scoshe kit that is direct bolt on but have not confirmed it myself. You should be fine simply removing the factory radio. The problems that arise from swaping the radio's are Door Chime goes away and your RPM gauge doesnt work. Thats a problem with RDS radios. It's a hit and miss cutting the data cable for the RDS. In my brothers S10 he had said problems. In my blazer I had no trouble at all.
Here's a crappy cell pic of my dash/headunit in:
https://i26.photobucket.com/albums/c...g?t=1245007737
mahoney1988 Jun 14, 2009 05:25 PM
like i said lol if you want the easiest fastest install get a single din with a dash kit.. i got a cd player on eBay that came with the dash kit and the wiring harness for no extra charge and also free shipping.. or you can drive to your nearest walmart and get the dash kit.
brian400ex Jun 20, 2009 04:43 PM
you lose your tach when u install an aftermarket radio?
pnice74 Jun 22, 2009 01:38 AM
Yeah, whats up with the tach?
brian400ex Jul 19, 2009 04:42 PM
can anybody confirm the losing of the tach when upgrading to an aftermarket hu?
tonyhonsberger Jul 19, 2009 07:07 PM
i have a 2001 and have had 3 differnt head units in it never had a problem and everything still works in the truck you should have no problem.
brian400ex Jul 20, 2009 11:03 AM
mine is an '03 with a rds radio. you sure i won't lose my tach?
