Radio Replacement Questions
I have a 2001 chevy blazer and I am looking to run a subwoofer cable cleanly from the HU to the cargo area, any tips or tricks?
i have a 96 blazer and i ran the wires from the head unit across the steering column inside the dash and down past the parking brake and all the way to the back i tucked it under the plastic on the edge of the floor so it cant be seen at all its pretty clean look for small openings to run the wires through just make sure nothing is going to pinch or squeeze the wires where you run them
The rds runs through the class 2 data bus to figure out what the tach signal is. there is no tach wire that goes to the radio. so you will be fine with replacement of the factory radio with the after market. still unsure if the 03-05 blazer extreme dash bezel will fit into a standard s10. because they redesigned the frame of the dash. everyone ive talked to either fiberglassed the dash or went with a flip out. even tho a double din navi looks so much nicer.
Boiler20
Oct 19, 2013 03:53 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
