replace speakers
im pretty sure i have the tweeter in the dash, but if i replace my speakers, would it be posible to replace them with the 4x6 plate speakers that are available on other blazers?
RE: replace speakers
you can put pretty much any 4x6 up there with a little trimming........I have infinitys 4x6 plate and it worked out great.
yeah not a problem i have MTX 4602's up there and they sound awesome.
but you will run into impedance issues if you wire them up. HU will not like seeing 2 ohms. You will have to wire them at 8 ohms. Cause it will eventually carap out on ya.
how do i change it to 8 ohms?
ORIGINAL: blazinloud you can put pretty much any 4x6 up there with a little trimming........I have infinitys 4x6 plate and it worked out great. |
basically, you will have to run wires from speakers in the doors up to the radio, and wires from the 4x6 to the radio. mark them individually. then wire them as follows
http://www.rockfordfosgate.com/rftec...hmSVC_8ohm.gif |
lol it really sux when u gotta raise the ohm load.
ok, ok well I didnt do the trimming, I had a shop put em in.....I seem to like to pay people to do things I dont want to........
no trimming that i can remember on pass side, the drivers side, just a little bit. have to take a corner off in the dash.
| All times are GMT -5. The time now is 08:23 AM. |
