replace speakers
Old Apr 24, 2007 | 09:55 PM
drperry's Avatar
Default RE: replace speakers
Those infinity's must be pretty thin... My RF's don't fit in either hole, lol.
Old Apr 24, 2007 | 10:57 PM
twei's Avatar
twei is an unknown quantity at this point
what if i get 8ohm speakers? then would i just be able to hook them to the back of the HU?
Old Apr 25, 2007 | 02:29 AM
hillbillyinOhio's Avatar
wouldnt suggest that. just wouldnt make sense to do that. i would really just get a comonent set, or stick with the regualar door speakers.
Old Apr 25, 2007 | 02:37 AM
blazinloud's Avatar
they are nice speakers.....but crackle and pop if I put any bass thru em........3 or 4" mid and a silk tweet.......sounds great....but not too durable.....I like the sound of those tweets more than the JL's [&:]
Old Apr 25, 2007 | 03:53 AM
BlazinInTheBlazer's Avatar
BlazinInTheBlazer is an unknown quantity at this point
Would there be much of a difference between these set-ups?
Rear- 6.5' kappa
Front- 6.5' kappa
Sub- 1x Type-R
Rear- 6.5' kappa
Front- 6.5' kappa component set
Sub- 1x Type-R
Would it just be smarter to go with the first set-up?? I'd amp the interiors either way... No clue what amp though!
[align=left] [/align]
Old Apr 25, 2007 | 06:51 AM
drperry's Avatar
For the best imaging, the second one would be best, the tweeters in the dash make a big difference... I've gotta get something mounted there...
blazin: I love my RF 4x6s... and they take a moderate amount of bass... They usually were pretty close to my 6x9s... I want them to fit! But as it stands, if I want them in, I can't have the speaker grille... At least until I find a glue that works with the factory plastic, so I can mod things a bit...
Old Apr 25, 2007 | 10:46 AM
blazinloud's Avatar
cant dremel it?
Old Apr 25, 2007 | 10:58 AM
drperry's Avatar
If it ends up that the speakers don't fit after all, then I'd like to be able to put the grille back together...
As it is, you can't put the grille and the speakers in at the same time, lol.
The front (closest to the windshield), there's approximately 3/4" of an inch between the speaker and the dash, when the back part of the speaker is flush against the dash mounting...
Old Apr 25, 2007 | 10:39 PM
twei's Avatar
would tweeters from a component set fit in the plate where the stock tweeters were?
Old Apr 25, 2007 | 11:44 PM
drperry's Avatar
The tweeters should fit, if they're 1" tweets... You might need to drill the hold a bit for the new tweeter to fit, but should bolt in otherwise...
