Speaker problem-again
Old Nov 29, 2005 | 10:28 AM
hdlogistics's Avatar
hdlogistics is an unknown quantity at this point
Default Speaker problem-again
I just replaced my rear mid panel 6x9's. I thought the driver side speaker was dead. The new speaker worked fine when installed but now it's not working either. Could this be the cd deck rather than a wiring issue? All the other speakers work fine. It has the factory am/fm/cd acdelco deck (not bose).
Thanks for the help.
Old Nov 29, 2005 | 03:02 PM
drkmelvin's Avatar
drkmelvin is an unknown quantity at this point
Default RE: Speaker problem-again
I would say a loose wire, or a bad deck
Old Dec 2, 2005 | 05:56 AM
blue_green_rider's Avatar
blue_green_rider is an unknown quantity at this point
don't want to sound too stupid saying this but make sure the ground wire is secure and not majorly crimped or stretched anywhere.
Old Dec 2, 2005 | 08:45 AM
I thought about something like that. Seems strange how it worked for a day then stopped. I'll pull the deck to check further. Maybe a good time to replace the deck too.
Old Dec 4, 2005 | 10:28 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
take out the "nonfunctional" speaker, turn on your stereo, and get a digital multimeter. test the + and - wires coming from the stereo and see if it reads anything. if it doesnt, then you got break in the wire somewhere or 1 of the channels in your stereos internal amp is fried. if it does, then test another speaker and see if the V readings are close to the same. if they arent, same problems i just mentioned. if they are the same, either its a weird fluke, or your speakers are bad. what kinda speakers are they BTW?
Old Dec 4, 2005 | 08:41 PM
I replaced the 2 6x9's with Clarion's. Once the speakers were replaced they each worked fine. When I got in the truck the next day, the driver side rear did not work again. I had the same problem with the original factory speaker. I'm wondering if the deck has a bad channel, would it only effect that one speaker otherwise it must be a wiring problem. The speaker doesn't cut in/out, so I'm thinking it's the deck. I must admit, even when the speaker was working, it didn't make much difference in the overall sound of the system. Thanks for the input.
Old Dec 5, 2005 | 01:45 AM
FatRyan's Avatar
yes, thats what i said, so i say get a new deck
Old Dec 5, 2005 | 01:48 PM
Thanks, I'll do that soon...
Old Dec 7, 2005 | 01:41 PM
Bocomo's Avatar
Bocomo is an unknown quantity at this point
I put a Pioneer in my 1999 Blazer to replace the standard Delco. It sounds so much better it isn't even funny. Makes me think I should replace the factory speakers, too.
Bocomo
Old Dec 8, 2005 | 02:12 AM
2000ZR2's Avatar
2000ZR2 is an unknown quantity at this point
i agree i think my 2000 Blazer as extremally good acoustical value you stock but with a aftermarket system it amplifies how good it is
c3478493
Feb 3, 2014 02:56 PM
gatelocked
Feb 28, 2011 04:52 PM
acavill
Jan 20, 2010 06:54 AM
KRUSHER
Jan 2, 2010 07:25 PM
ige2201
Feb 9, 2006 03:31 AM
