Speaker Size
Old Feb 15, 2008 | 11:26 PM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
Default Speaker Size
First, thanks to this forum, its been a great help.
Next, my question.
What size is the speakers located in the door of my 97 S10 Blazer (2Dr, 4WD)?
Also what would be a viable reasonably priced replacement?
Old Feb 15, 2008 | 11:53 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: Speaker Size
6.5"
If it has the bose package its an 8" radiator
Old Feb 16, 2008 | 03:39 AM
oakleyg's Avatar
oakleyg is an unknown quantity at this point
The bose is actually 7'
Old Feb 18, 2008 | 09:53 PM
danmiranda's Avatar
Well, My Blazer does not have a Bose setup, therefore what speakers do you guys recommend? Im willing to spend some decent cash, but nothing excessive.
Also a kind of related question, when I shut my Blazer off, the clock stays on the Delco Deck, how do I fix this? Its completely off, but the clock stays lit no matter what.
Old Feb 18, 2008 | 11:01 PM
mdehoogh's Avatar
ORIGINAL: danmiranda
does it turn off once you open the door? the clock on my old Delco one and newer Pioneer one both stay on and play music even when the truck is off. if the door is open, however, they will shut off
Old Feb 19, 2008 | 07:30 AM
danmiranda's Avatar
It doesn't play music, or do anything, the clock just stays lit. The ignition would be off, and the car would be totally off, no power to anything else, the radio's clock stays lit reguardless. Its driving me nuts, yesterday I had to jump her as the battery had died cause of it.
Old Feb 20, 2008 | 09:53 PM
Butts's Avatar
Butts is an unknown quantity at this point
Sounds like your Ignition and Constant wires are mixed. Maybe the illumination wire is somehow getting power from a constant.
Old Feb 25, 2008 | 11:47 PM
El_Beautor's Avatar
It could be a problem in the Deck itself. If you're replacing speakers, you might want to consider replacing the head unit as well. The factory deck is pretty weak on power output, and you could check the wiring while you have the deck out to see if there is something wired wrong, or if there is a circuit that is retaining power when it shouldn't.
c3478493
Feb 3, 2014 02:56 PM
rick465
Aug 25, 2006 09:37 PM
jflachs34
Jul 13, 2006 05:15 PM
thanser
Dec 8, 2005 02:59 PM
Jnike120
Nov 28, 2005 01:29 AM
