Speaker Size
Old Nov 30, 2006 | 03:46 AM
aman_darred's Avatar
aman_darred is an unknown quantity at this point
Default Speaker Size
Hi, I just bought a Blazer ZR2 two door. I need to replace the rear speakers because they dont work. The problem is it seems like I have to remove a huge panel to access them. Is this correct? Also, what size is the rear speaker?
Old Nov 30, 2006 | 10:29 AM
hillbillyinOhio's Avatar
Default RE: Speaker Size
They are 6x9's, and you don't have to entirely remove the back panel, just most of the way. when you remove the old speakers, cut off the connector all the way up by the speaker. then get about a 9 inch piece of speaker wire and connect to that factory wires. for drivers side, Brown is positive, yellow is neg, for pass side dark blue is positive and light blue is negative. Sometimes they don't give you enough speaker wire to have any slack.
Old Nov 30, 2006 | 10:38 PM
thanks for the timely reply. Dont you have to remove the whole panel to screw in the new speakers?
Old Nov 30, 2006 | 11:23 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
no jus pull it back and get a short screw driver and you are to go. it actually pretty easy to do prolly took me botu 10 min to do each side.
Old Nov 30, 2006 | 11:25 PM
alright thanks alot.
c3478493
Feb 3, 2014 02:56 PM
rick465
Aug 25, 2006 09:37 PM
jflachs34
Jul 13, 2006 05:15 PM
thanser
Dec 8, 2005 02:59 PM
Jnike120
Nov 28, 2005 01:29 AM
