Speakers stopped working!!!!
Old Dec 7, 2007 | 04:17 PM
CamaroManBlack's Avatar
CamaroManBlack is an unknown quantity at this point
Default Speakers stopped working!!!!
I was told that speaker issues are common with these "newer" Blazers. I just put a Pioneer CD player in my vehicle, and now only the front left speaker works. The front right one worked when the factory deck was in, but the rear ones have not worked since I bought the vehicle.
Anyone ever had this happen? (The deck is good)
Old Dec 7, 2007 | 05:50 PM
mdehoogh's Avatar
Default RE: Speakers stopped working!!!!
are you sure everything is wired up correctly?
Old Dec 7, 2007 | 05:56 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
im not sure if that is a common problem w/ blazers. make sure all your connections are going to the right places and are they all connected well?
Old Dec 7, 2007 | 08:21 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Do you have the Bose system. If so I would venture to guess that the factory amplifier is going out since you had issues prior to removing the factory system...Was the new Pioneer professionally installed or done by a friend/yourself?
Old Dec 8, 2007 | 09:13 AM
It's not Bose, just a plain tape deck system. I used the plug-in aftermarket wiring kit, so that I didn't have to cut the factory harness.
I do get a very faint signal to the speaker in question, but it's just light static and broken up faint pieces of the music I'm trying to play.
I'm going to do some tests today to see if I can isolate the problem...but I think I'm going to end up running all new wires...
Old Dec 8, 2007 | 10:59 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
Id have to say you wired the harness wrong. Double check the wiring and have someone else who knows how to do it check the wiring as well.
Old Dec 8, 2007 | 12:10 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
if everything is wired up correctly then your speakers could be blown, my driverside door speaker was blown and didnt work, i put a new speaker in it and now it works.
jstutzman
Dec 19, 2009 03:27 PM
jess1327
Mar 8, 2008 07:46 PM
acedrr03
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jan 17, 2008 10:37 AM
mac6135
Dec 8, 2007 09:18 AM
Stablock
Apr 20, 2007 04:29 AM
