Stereo Wiring and Install Parts
Sounds like you got something hooked up wrong and either the internal amp is shutting itself off to protect it from a short or you've already blown the internal amp.
Another possibility is that the HU has an option to turn off the internal amp and you accidentally turned that off, but it's not very likely as you'd probably have noticed when you did that right away and prompted turned it back on.
Did you cut the factory plug off the harness?
I have a 98 ls 4dr. I've been running a pioneer aftermarket for a few years with no problems. Out of no where I lost all volume except a small amount coming from the passenger dash speaker. I've tried other stereos with same results. Does any one know where the wires go after they leave the stereo? Do they go straight to the speakers or do they meet somewhere before the speakers?
It had the factory stereo in it years ago but I replaced it with a pioneer.
I only had the front 4 speakers hooked up. Dash and doors. It's really hard to imagine all 4 speakers going bad at the exact same time because I didn't have the radio turned up at the time. I was trying to when I noticed it.
Even if all 4 failed a continuity test I still couldn't believe all 4 went out at the exact same time without something major shorting them all out.
You can get antennas in about any auto part store. It doesn't have to be especially for a blazer. Keep in mind that the oe radio uses a different size plug than most aftermarket stereos. So get the adapter if needed.
The adapter is probably what I am looking for but the local parts store doesn't have it.
