Stereo Wiring and Install Parts
You seem to know a bit about wiring. Wondering if you could answera few questions? Got a 97 s-10 blazer. Im installing a in dash dvd/cd player. If it helpsthe brandisa VP3 and model is VRVD630. Got everything hooked up and running besides the picture on the screen. It wont allow picture because I need to connect a wire to the parking break that disables the picture whenever the vehicle is not in park. Where is that wires closest point to the dvd player and what color would it be?
Andy
Andy
It is usually just a matter of grounding that wire!
The hole in the dash is to small needs tobe cut away but im fine with that i just want the proper mounts to hold the double din in the dash securely
ive never really looked into this before...im not sure if there is anyone out there that has but i would assume you could just fab up some custom mounts really easy. i would just grab a piece of sheet metal and rivet it to some existing structure somewhere in the dash...this is just what i would say =/ you also might have to make sure it is properly isolated idk
So has anyone been able to connect an amp with the factory Bose system? I'm thinking of adding an new HU and would like to add two subs as well. I bought a scosche fai-3a output converter, has anybody used this with any luck?
So I decided to replace my dying Pioneer cd player in my 99 blazer today. I bought a new Sony CD Player and attempted to install it. I matched up all the wires and the player kicked right on. When I went to put it in the dash, the new cd player quit. It will still accept/eject cds but not play music.
I need help.
It seems like there is an overabundance of wires, including two that aren't even connected to anything.
Helpful hints, or somewhere you can point me that can give me some pictures or instructions?
Thanks!
Samantha
I need help.
Thanks!
Samantha
I connected my bose system without the output converter, everything seems to work with no issues. Also like stated above the blue/white wire needs to connect to the blue wire in the wiring harness cable. In my case it wouldn't play any cds or my ipod until i connected the blue/white from the HU up with the blue one in the harness.
