Subs are popping and its not cool!!!
Alright, So To start i Have 98 blazer :]
I have 2-12 subs http://www.crutchfield.com/S-1fmtNNj...s-Package.html ... And http://www.pioneerelectronics.com/PU...rs/DEH-P4100UB Head unit. Few months ago I hooked up my subs..:icon_speaker1::icon_speaker1: all honkey dorey. The power cord to the amp from the battery broke. Waited till now To get a new cord.. So after i hooked everything all up. I turned it on and my subs.. are going Pop pop pop pop pop.. With out any music whats so ever.. I disconnect the RCA's to - HU. or even just the speaker wire from the amp to the subs.. and it stops... I have tried a new ground didnt do anything so if anyone has anything on why or how to fix this Or need more info Please let me know!! Thanks in advance! |
try a inline noise filter from walmart its A SCHOCIE BRAND PLUG IT INTO UR AMP IN THE RCA PORTS AND PLUG UR RCAS IN THE FILTER. had same problum and that fixed it
and inline filter is just a bandaid for a bullet wound. Meaning its just going to mask a much larger problem. My guess is that you have cheap RCAs. Try a new set of RCAs and it should fix your problem.
http://www.knukonceptz.com/productMa...y=RCA%20Cables |
Originally Posted by bobditts
(Post 316325)
http://www.knukonceptz.com/productMa...y=RCA%20Cables Thats What i heard about inline filters. I also thought it might be the RCA's But even when i unplug The Speaker wire from From the amp To the actuall subs. Its Stops. So again any ideas. |
also make sure your rcas are not near the power wire. i found out that's why i was getting the popping after that i ditched the filter. but the best thing is to go to the local car audio shop and pay um $25 to trouble shoot it!
Originally Posted by DevinIsPro
(Post 316582)
are you saying if you unplug the subs from the amp, the noise goes away? |
Yea, Or the RCA's. I heard it could be a bad ground so i did a completly different one.. Just confusing seeing as it worked a month or 2 ago.. could putting the subs in a differnet spot in the truck change anything? Again Thanks for all your help. By the way.
NEW INFO!!!!!!!!
Okay... So I re undid everything all over again!!!! Now Its still making the rapid popping noise once both rca's are in But when I leave just the "R"(Right) or the red Port in the AMP I can hear bass from the music quite alright... but as soon as i plug in the "L"(left) or the white port in the AMP it goes rapid popping.. I switched around the RCA's (thought it was a bad cord) but still the same thing happens so its not the cord. this time any ideas any similar problems? |
either subs are blown or rcs, or the ports on the amp are bad, or the amp is bad itself, or could be a wire
like a previous guy said just take your truck to a shop, have em test it. |
its either a bad output from your head unit, or a bad input on your amp.
