A sweet upgrade
Old Jan 19, 2008 | 10:34 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: A sweet upgrade
ORIGINAL: Tippman7641
lmao this is the current amp i will use for the time vbeing
http://www.hifisoundconnection.com/S...id/0/SFV/30046
this amp will not work unless you want to severely underpower your subs at 6ohms
Tippman7641's Avatar
Tippman7641 is an unknown quantity at this point
ok ok slow down simple langue please, enginner language(simple)
just give me a few amps and prices if you want to please
o so no matter how high i putthese subs n my current amp they wont be damaged??
ok no offesense. i can wire up the most complexe amp setup an d hide wires like they were placed by the factory, but i can never figure out the amp configuration and you guys talk like at least to me like you knoa all, like i said before no offense
here is old speakers
Old Jan 19, 2008 | 10:52 PM
hah will you guys finnly respect my system once i get the proper amps with these speakers? lol
Old Jan 19, 2008 | 11:01 PM
bobditts's Avatar
with 2 dual 6ohm subs, you can either wire them for 1.5ohms or 6ohms. Each sub is 300RMS so you need to find an amp that will either pump out a clean 600RMS at 1ohm or at 6ohm. Since 99.9% of amps will not have a rating for 6ohm, a 1ohm stable amp will be much easier and cheaper to find.
Old Jan 19, 2008 | 11:05 PM
could you recomend some please? oh and how should i wire wire my current amp for right now?(yes i now they are underpowered
Old Jan 19, 2008 | 11:08 PM
mdehoogh's Avatar
Orion HCCA-1200D 600rms @ 1ohm
Directed D1200600rms @ 1ohm
Old Jan 19, 2008 | 11:09 PM
thats so expensive for my current budget i could cry\\
id only need one right, just need to bridge right?
thanks btw
Old Jan 19, 2008 | 11:12 PM
mdehoogh's Avatar
well, you dont have to buy it from the manufacturer (both are the same company, likely the same amp internally) i was looking for ebay links for them and you can get the orion for $215...
what is your budget? its difficult to suggest amps without having an approximate price range
on a MONO amp, there is nothing to bridge. one [-] speaker output and one [+] speaker output...
Old Jan 19, 2008 | 11:13 PM
i wann say 160 but i can save for a few eeks to like 300 MABE
o and should i do that for my current amp?? just for now?
Old Jan 19, 2008 | 11:18 PM
mdehoogh's Avatar
PERFECT!
600rms for $170.... it would be best to wait for some more input from some of the more experienced guys. im not sure on the quality of Directed amps...
a good place to look is www.onlinecarstereo.com on the left column, select MONO AMPS and look through them, you want to look for an amp that puts out 600+ rms @ 1ohm.
