System Help-Clarion
Old Jul 16, 2009 | 09:14 PM
R3DxDR4GON's Avatar
R3DxDR4GON is on a distinguished road
Default System Help-Clarion
Hi All!
I just recently purchased a Clarion VRX925VD. When I installed it, none of the button lights worked, nor did the screen work. Any ideas as to why this could be?
Old Jul 17, 2009 | 01:55 AM
bandidolenny's Avatar
You did hook up all of the wires correctly right? Where did you ground to? Do you have another head unit that you can put in it's place to see what happens?
Old Jul 17, 2009 | 11:29 AM
02BeachBlazer's Avatar
02BeachBlazer is on a distinguished road
well to test out to see if it works just dont even like install it just take the power wires it make it touch the (+) on your battery and do the same with the ground wire but make that touch the (-) of course and if nothing happens then its ****ed up and if it turns on then you hooked it up wrong or your wiring harness is bad
Old Jul 20, 2009 | 07:07 PM
R3DxDR4GON's Avatar
Well, I found that the radio fuse was blown, so I just replaced that with a new 10A fuse. When I get the radio back, I'll see if it works. I was also told that grounding is a big issue with in-dash dvd players.
altoncustomtech
Jan 4, 2013 11:08 AM
liltittle62
Dec 26, 2010 03:55 PM
HowlingX
Jan 18, 2009 01:30 PM
Numba1Sean
Dec 28, 2008 09:34 PM
blazinloud
Dec 26, 2006 03:00 AM
