System issue...
Old Jan 14, 2008 | 08:20 AM
mdk681's Avatar
mdk681 is an unknown quantity at this point
Default System issue...
Hey guys. I'm having some troubles with my system lately and don't know where to start. I recently moved my equipment around a bit and ended up moving my amps back to where they were initally; on the back of my rear seats. Last week one of my buddies sat in the back seat and all of a sudden, POP... Then a bunch of feedback came. Now every time I turn my volume above 0 my speakers POP super loud, and I get a bunch of wierd noise in my speakers and can't even listen to them.
I have tryed removing the RCA's from my sub amp and turning it up andit still happens to both my speakers and my subwoofers (I have 2 seperate amps). I have checked all of my connections for loose fits and I can't seem to find anything.
I have a feeling it may be a grounding issue; does this sound like somthing that could be giving me the feedback and wierd noise? I need to figure this out ASAP, I can't live without my stereo! Help!
Old Jan 14, 2008 | 08:38 AM
hillbillyinOhio's Avatar
Default RE: System issue...
do you have access to a DMM (digital multi-meter) if so, check the resitance of your ground
Old Jan 14, 2008 | 10:31 AM
mdk681's Avatar
Yes, I do have a DMM. What setting should I put the DMM on when testing and where should I touch the leads to?
Old Jan 14, 2008 | 11:07 AM
resistance (ohms) and the batt and where your amp is grounded. first zero your meter out and check for resistance in your leads.
Old Jan 14, 2008 | 11:23 AM
mdk681's Avatar
Ok, I will do that. What should be the ideal reading that I will get, should it be 0? I really don't know what would be good or bad...
Old Jan 14, 2008 | 02:45 PM
mdk681's Avatar
I just got done testing my ground with the ohmmeter, it instantly went to OL (Overload) on my meter when I touched the positive and ground cables... This seems bad, should I change my ground location?
El Diablo793
Sep 18, 2011 01:11 PM
troll711
Jan 23, 2011 08:26 PM
liltittle62
Dec 26, 2010 03:55 PM
caity769
Feb 26, 2009 01:16 PM
Painkiller1990
Sep 17, 2005 02:34 PM
