Temp display in 00 Blazer
Old May 15, 2006 | 06:09 PM
LT1KICKER's Avatar
LT1KICKER is an unknown quantity at this point
Default Temp display in 00 Blazer
My temperature display in my overhead console hasn't been accurate since I bought the truck. Lately it's completely off. It registers very low, like 14* on an 80* day. Any way to fix?
Old May 15, 2006 | 08:18 PM
MCas86's Avatar
MCas86 is an unknown quantity at this point
Default RE: Temp display in 00 Blazer
press the button that says US/Met i bet u have it as metric and not US
Old May 16, 2006 | 09:08 AM
If that doesn't work (or if it's set correctly), you may have to replace your exterior temperature sensor. It is located behind the grill / in front of the radiator/condenser and is clipped to the vertical hood latch support.
First I would atleast remove the sensor and check the connection. If it's corroded, that could definitely throw off your readings. I believe that the sensor itself isn't much more than $20 from the dealership. If you have automatic climate control, this poor reading may throw your HVAC system for a loop. This sensor gets used by the climate control to figure how aggressive it needs to be with heating/cooling.
Old May 16, 2006 | 11:49 AM
LT1KICKER's Avatar
Thanks guys. No, it's definetely not on Metric. I do have computer climate control, but I don't use it (I think the wife does). I have a Gentex temp/compass mirror in my 95 Caprice and it's doing the same thing, so I think I have a bad sensor.
jweber228
Mar 21, 2012 12:33 PM
zakm0n
Jan 9, 2011 07:31 PM
dravengary
Nov 9, 2009 10:36 PM
DaddyCop03
May 11, 2008 09:07 PM
blznlowxtreme
Dec 16, 2007 08:12 PM
