Is there a better way to remove the radio
Old May 24, 2009 | 11:12 PM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
Default Is there a better way to remove the radio
I know ya gotta take the dash apart to get the headunit out but is there a better faster way, i just wanna check the back of it and dont wanna take all that time, i will cut the trim around it to get to the bolts if i have to
Old May 25, 2009 | 06:42 AM
Biohazed's Avatar
on the 95-97 really there is not.. you have to pop the front bezel off (which really doesn't take that long to do) then unscrew the AC control and the radio. Unless you have a aftermarket radio then you can use the keys that came with it and slide it out of its cage.
Old May 25, 2009 | 07:14 AM
Sisk's Avatar
It's really not that bad, it's just a few screws and the front of the dash should pop off. It's a lot easier then thinking about cutting trim out.
Old May 25, 2009 | 09:38 AM
blazinloud's Avatar
hardest part is disconnecting the 4 wheel drive harness, at least for me, the wire is like 3" long.....but other than that very simple.
Old May 25, 2009 | 11:31 AM
Yea thats the thing, with my luck I would take it apart and not be able to get it back together
Old May 25, 2009 | 01:08 PM
Sisk's Avatar
Take pics along the way as you take it apart. If you forget, you can refer back to them to make sure you're putting it back together right.
Old May 25, 2009 | 07:37 PM
Biohazed's Avatar
the 4x4 switch is easy to deal with i usually pop the whole thing out once i got the bezel loose, the turn it 90 degrees and push it through the hole it sits in then its out of the way. the BIGGEST thing you need to watch out far is the hazard switch.. when you are working the the bezel out of the gaige area... be careful ... its real easy to break the hazard switch off.
Old May 25, 2009 | 07:42 PM
Well I dont think im even gonna bother lol, I just wanted to get back there and take a look at it, I always take crap apart to see how it works lol
Old May 25, 2009 | 08:09 PM
Lifted02Blazer's Avatar
Lifted02Blazer is on a distinguished road
i think its easy to talk it apart that way i use to have to tear my whole dash off to get to the radio the clips are so easy instead of 35 screws and bolts
shadow03
Feb 9, 2013 09:46 AM
Ugly_Monkey
Jul 23, 2012 01:38 PM
chris015
Engine & Internal
Jul 25, 2011 09:13 PM
rknight
Jul 23, 2010 07:19 PM
mpaczosa23
Dec 12, 2008 05:30 PM
